A lot of this I have posted on a couple of other Forums as a 'as-it-happens' build thread, but I thought I would post my Conversion here. However, I thought it might be of interest to separate the conversion into specific areas that might be of interest to potential - and maybe experienced as well - self-builders
I'll start off by introducing the vehicle and some general targets for the conversion ....
My intention is to make a decent conversion and to do everything where possible myself. And also to challenge the norm and do it 'my way' - so many of the things I will be doing may be seen as unusual or 'wrong' because they are not the typical way things are done in a Motorhome or Campervan!
Maybe some of the things will not work as I plan or expect - but in those cases, I will share with you the failures as well as the successes
This is the base vehicle.
ParkedUp by David, on Flickr
It is a 2003 VW LT46 LWB with just 125,000 Km recorded and fitted with the 2.8L 158BHP engine, which is renowned to be the best engine in the LT Range
It is a 16 Seater Minibus that started life as a 'Skoolie' in the Service of Nottingham County Council. As such it has has a fairly good life in terms of servicing and I have a long summary of the various work that has been carried out provided to me by the Council workshops.
The MOT History shows a good record as well. Prior to me viewing the vehicle, the only fail was a main beam bulb had failed back in 2010.
The Van did fail the MOT on the test I had requested to be carried out prior to buying as a condition of purchase - but that fail was the old 'excessive play' fault that Sprinters and LTs often get incorrectly failed on, so not really a fail (but the seller replaced the parts as he was not aware of the Mercedes foible in this area).
So in Summary it looked like a good platform for my conversion More will follow.
