I am thinking of getting an additional Leisure Battery, however there are a few factors influencing my decision:
Additionally there is a not so good generic 70AH Sealed Lead Acid in the front of the Van which has been made very challenging to remove/replace since the Gas (LPG) Upgrade.
I have effectively isolated the two batteries, though I can (if needed) connect them to allow for Solar Charge to Both or for Trickle Power Charge from 240V outside or Split Charge Relay from engine alternator and also to have a Max of 230AH available to Habitation, though it is never that.
I am thinking of adding another battery into the Mix and am wondering if it will mess things up or reduce the life of the LEOCH AGM if I were to also put in something like this https://www.alpha-batteries.co.uk/12v-130ah-leoch-adventurer-agm-leisure-battery-lagm130/ OR even this, which is slightly different Technology
Lastly spotted this on EBAY which seems quite cheap but no idea if it is any good
Any ideas ?
Cheers
Robert
- Budget
- Space (dimensions available to place battery)
- Technologies
12V 115AH Leoch AGM Lead Carbon Deep Cycle Battery (LDC12-115-G31-DT) (SLCA-12130 DT) - Alpha Batteries
12V 115AH Leoch AGM Lead Carbon deep cycle battery – LDC12-115-G31DT What Makes Lead Carbon AGM Superior to other AGMs? […]
12V 135AH 135 AH Leisure Battery DEEP CYCLE for Motorhome / Caravan / Campervan£ | eBay UK
DEEP CYCLE - STARTER CAPABILITY AS WELL. SPECIFACATION 135AH@C100 DEEP CYCLE LEISURE. Suitable for dual power use: starting and deep cycle. VERY HIGH LEAD CONTENT. We are a leading independent battery specialist in England.
www.ebay.co.uk
Any ideas ?
Cheers
Robert
