groyne
A lot more involved than two bits of pipe to join my friend.
Spoken like a true plumber, have we met?
This is one of the most irresponsible posts i have ever read on here - especially to a question from a new member........ i am surprised at you Alan
van gas leak has appalling results.....
GASSAFE register do have LPG fitters, although there are not many of them ..... call GASSAFE tomorrow and ask if they could find an engineer in your area ?
but the original new poster asked for someone else to do it for him - someone he could trust and who was qualified.... presumably he asked that because he does not know how to do it. Neither did i when i first bought my van.
i learnt from bitter experience on this forum that as a newbie you do not know whose advise to listen to and you dont know who knows their stuff and who doesn't .... after all.... newbies dont even know what they dont know let alone know what to ask .....
i have had some appalling awful stuff done to my van by cowboys - and will now only use properly qualified people.
i have worked with gas for many years in my business and know the damage it can do - as do we all.
I still say that recommending that a newbie "does it himself" is really irresponsible.....
and i still say all thats needed is a competant person ,
i never said do it yourself .
competant person . thought by now you might have looked up the word competant .
as i said or it was said gas safe or the old corgi dont cover private m,homes . only ones for hire .
i know really its a problem of words written on a forum . in real conversation it would be easier to explain .
but the rules say competant . i used the same word. wasnt meant to offend .
i also have seen so called caravan /camper places make a right mess of things .
if you use a tyre foot pump with a gauge on and adapt a rubber hose to fit the pipes you can do a pressure test without even putting gas into the pipe work.
i can open anyone of my three lines and check them. if ones leaking fix it .
after all plumbers used to go on a couple weeks corse and turn up on building sites with a nice new canvas bag and new tools .
everyone knew them as bagmen . some were ok others not too smart.
i,m glad i trained as a butcher . learnt alot hee hee .
An air pressure test is fine for pipework but if you put more than operating pressure into a system with appliances or regulators connected you can damage components.Bearing in mind the operating pressure can be blown into a pipe with a good puff of the lungs a foot pump raised pressure could also cause excessive stress on joints never intended to reach those pressures leaving your system more susceptible to stress fractures through over pressurisation.Easy this joining two bits of pipe together isn't it!
