		Thought you might like to know that after some faffing and opening a Support Request with TP Link I have now created a small routine to Turn on a Van heater at A specific Temperature range and turn it off at another temperature range.
The device I used was a TP Link HS100 - It is a pretty neat Smart Plug albeit a little on the large side, link here
I tried a Teckin Smart Plug as well but that was awful to set up so I sent it back
The routine is fairly simple. First off head over to IFTTT and sign up, if you don't already have an account, here
When you have your SmartPlug registered on Kasa Cloud from TP Link you can use IFTTT to create a routine where a query is sent to Weather Underground for Temperature in a location (where your Van is parked) and if the temperature drops below say 3 deg Centigrade then the Smart Plug is switched on, that is connected to your electrical heater over EHU. Pretty neat I think. Then simply do another routine to turn off the Smart Plug.
If you have your own Weather Station integrated into Weather Underground then that is a better solution, sadly my old Maplin Weather Station went Bang a few years ago and never got another one to replace it with.
