(Edited to remove other item no longer available)
Undercounter 93L 230V Compressor Fridge
It is this item here - https://amzn.to/2SEkcNg
I fitted one of these in my Camper Conversion in 2017 and it worked brilliantly and never missed a beat. I would leave it on 24/7 summer and winter.
More economical than the majority of 12V Compressor Fridges costing 4 times the cost and twice as roomy. And over 10 times more efficient than a 3-Way used on 240V.
I bought this one that is for sale in 2019 to have either as a spare or for a new project but never used it until a couple of weeks ago as a temporary option when my much more expensive and much less efficient 3-Way started playing up (and I removed it to troubleshoot).
So this is virtually brand new with just a couple of weeks use (and coming out again within a few days when the permanent replacement gets installed).
It is suitable for use in a camper (with an inverter) or is equally good in a regular domestic environment.
For use with a camper, I have added a little travelling catch to secure the door which works really well and is very unobtrusive.
Superbly efficient and looking for just £70, which is an incredible bargain for a essentially brand new Class A++ Fridge!
The following graph shows how little power the Fridge uses. When the compressor is running, it draws around 38W, but the compressor only needs to run around 1/4 to 1/3 of the time to maintain the temperature, which means this fridge is extremely efficient, even when used via an inverter (I have my inverter set to only come on when the fridge demands it, so virtually no inverter power draw happens for most of the time)
