high temperature adhesive removal
tony280
I have some van lining coming away but its only where its stuck onto vinyl material so am removing it
How do I get glue residue off
FULL TIMER
found some glue/label remover in aerosols in Lidls the other week, just spray it on leave for a second or two and wipe it off, was excellent stuff and had a sort of orange peel smell to it, trouble is you never know when they'll have it in.
vwalan
autosmart do a jelsol .just for that purpose .in aersol .ask a good car sales place to get you one as autosmart are trade sales only supposedly . bit like snapon . but if you see one and pay cash they usually will sell it to you .
molly 2
adhesive removal
Hi 3 m adhesive remover /cleaner . Do a test spot first .Their is no easy way soak in the cleaner and scrape off .could be worth trying just glue it back with carpet adhesive . bazz
Deleted member 951
WD40 removes glue residue, as long as the surface is easily cleaned to get rid of the smell of the WD40.
voyagerstan
upvc cleaner from window suplier but be carefull left to long it melts the plastic :) stan
REC
I love WD40, also I got some medical adhesive remover (freebie from a drug company) and that works well for most glues.
