shortcircuit
the reason i use conduit cable -its mutistrand
NOPE. It is for a fixed installation only and not a MH. It may well be multi-strand but not enough multi-strands and therefore subject to cores breaking.
Having built my own camper I offer these words of advise. Try to mount your bottle so that it is accessible from the outside, in a locker that is sealed from the rest of the camper. As the gas is heavier than sir and will sink try to have a vent at the bottom. I also installed a gas detector in my bottle storage. If it has to be inside the van then make sure you have a gas detector that will detect both carbon monoxide and propane/butane.. They are Vailable on eBay.
If you get stuck with the wiring and fancy a trip down to Suffolk then I am on holiday from the 10th nov for a week and will give you a hand woth it.
The OP has stated he does NOT have the knowledge to carry out anything but the simplest 12V wiring and certainly not mains wiring.
Are those who insist on coaching by remote control going to accept full responsibility for anything that goes wrong?? Full names and addresses perhaps???
No, I thought not.
Duty of Care defined
