RogueCamper
Hi I'm new here, I am converting a exLWB crafter into a motorhome.
I am doing the gas at the moment, I am pretty competent and will have it all checked and pressure tested at the end.
It is a fairly simple set up,
-gas bottles at the back, 8mm pipe running the length of the van to a 2way manifold
-One outlet to a spinflo triplex cooker, one to a Dometic fridge.
I obviously need 2 straight couplers to connect my appliances to my copper pipes but the inlet pipes on the cooker and fridge
Seem to be stainless steel??
My question is do you use steel compression coupler and olives or a copper one.
Will a copper coupler bond to the steel pipe, and visa-versa.
Or can you use a steel coupler with a copper olive on the copper pipe side??
No one seems to mention this being an issue, they just say- connect the appliance....
Any help appreciated
Grant
Grant
