GRWXJR
Ok... this is just an idle thought (cooked up while I was underneath my van tinkering with something).
As we like to get away in the van at any opportunity and in any season, it'd be good if the camper had some better floor insulation. However, I have already done the inside floor and in any case can't really afford to/don't want to lose any height.
Now, my LDV has a lot of ground clearance, and also a fair amount of clearance even between the running gear/exhaust etc. and the floor.
The floor is the usual sheet steel, and is reinforced by box section struts (as well as the main chassis rails). The suspension is leaf spring with masses of room between it and the floor, so there's not much getting in the way of most of the floor.
The underside has been recently undersealed (Waxoyled) throughout. Inside there is a thin foil type insulation barrier on top of a ply floor, and the top finish is laminate flooring.
So... my thinking was... could I get a much better insulated floor by using all that dead free space between the strengthening struts and insulate the floor from UNDER the van - outside instead of inside - sort of 'cladding' the floor? Can I 'fill in' the spaces between the crossmembers etc. with something like 50mm Sellatex to insulate (most) of the habitat area floor?
I thought about potential to trap water etc., but the floor is undersealed, plus I thought I'd coat each piece of infill Sellatex section with underseal before sticking them into place. I don't think fitting insulation is a difficulty - but the consequences for causing rust of other issues are my concerns.
Anywhere where the exhaust might get a bit close for comfort I can leave, or I can easily heat safety wrap/lag the pipe (I already have done the front section as an extra noise insulation move. As a bonus I thought the floor insulation would give welcome extra noise insulation as well when travelling (Tranny Di engines and transmissions/axles do make a bit of a racket).
So... is this viable or a "bad idea"? If I'm talking nonsense - is there a better under-body solution or material to use that would accomplish this? Or, do I just live with it and burn a bit more fuel through the Webasto instead?
(BTW - the rear part of the van is storage/services, and the main fuel tank and the night heater are under this area, so I don't need to worry about doing anything anywhere near these things anyway, and I wouldn't be daft enough to cover/bury any of the fuel lines etc.)
Thanks in advance of any assistance / advice rendered!
G.
G.
