jonnyboy
Hi all, I have a Renault master 2006, dci 120, I have a leisure battery that is connected via a Durite split charge relay. My question is, Could the leisure battery or the van battery drain each other if still left connected when not used? I forgot to disconnect the power to separate them when last used and now i find both batteries are flat? I intend to check the circuits to see if there is any drain but it has been a long time since the leisure battery was last used and i should have recharged it. Anyone know if this is possible?
