BillyPants
The simple calculation is to divide the watts by 12 and that will be roughly near the current. Remember the load Watts is the same in or out of the inverter (forgetting losses) Current for 170w @ 230 volts = 170/230=0.74amps. Current @ 12 volts = 170/12= 14.17amps
If you are using the 1000watt inverter you will be wasting a lot of power just running the inverter and reducing battery life having said that you have a large battery bank 2@225 A/h= 450A/h (@12volt?? they are not 6volt batteries?). I have a 300w inverter and it runs tv, laptop etc
They're 12 volt yeah. I have a gennie, but only need it every 4 days or so if I don't move around, much less if driving. The large inverter was a bad buy from wayyyyy back when. I had a much smaller one that sadly died last year so I just put this one in. It takes about an amp when the lappie is on.
I'll try that formula with a few things shortcircuit, thanks.
