bartman
Although I drained the water tank, I have frost damage at the tap due to the water residue there. When the tap is run, the leak is from the region of the base of the tap.
Having undone the back nut under the basin, in order to lift it out I need to disconnect the tails from where they connect to the system. The problem is that I don't know what type of joint I'm looking at. It looks like it might be a John Guest push fit, if is that it is seized with limescale or similar. I'm hoping that somebody here will recognise the fitting and can tell me. I'm also puzzled as to why the hot water fitting is different with the button on it
