Citoren Relay 2022 Single seat pretensioner check airbag fix
ConnorThomas
Hi everyone!
I'm wondering if anyone has had this issue with NEW citroen relays. I have a new (2022) citoren relay and attempting to swap out the double bench seat for a single OEM passenger seat. When connecting up the new seat, we get the 'airbag check' error. We believe this is because there was previously two seatbelts, but now only one.
I've heard about the 2-3ohm resistor trick, however we can't seem to see anyone with the same 'orange connector' that both or drivers and passenger seat has.
I'm wondering if this is where we would place the resistor? Photo attached.
PeteS
What was the connections on the bench seat you took out?
You may also be able to take it to a dealer and have them disable the second seat
