Interesting point Dave. Kerosene, paraffin, heating oil, not sure if there's a lot of difference between these three things; certainly, a lot of people favour heating oil and red, if you can get it, paraffin I think is a bit too expensive. Once mine's up and running I'm going to try and run it on sump oil. In my motorhome I run a very lightweight oil 5/30 and because the engine runs on LPG there is no carbon in the oil and, basically, it comes out the same colour as it went in. I may have to mix it 50/50 but will see how it goes.
You mentioned about ramping up the temp/pump frequency, the way that I intend to get round this; initially we were going to have the heater under our seat but now have opted to have it in the back of the van where the original heater was positioned. This way we can heat the toilet/shower room up and, if we leave the door open, that heat can then drift into the kitchen area. The rest of the heat will be piped down to just behind the driver & passenger seats; by doing this, I can warm the van up completely and run the pump at a higher temperature and, hopefully, this will assist in making a clean burn........another one of those 'suck it and see' things.
Last of all, the clips. I have both types; the ones in the picture and the single wire. The thing I like about these is they will always be tight as they are spring actioned and so no need to go round tightening.
Rae
