CBE DS300-UK wiring
A11an
Hi, Hoping someone can help please.
I'm just replacing the electrics in my father-in-laws van and not sure how to wire the 12v sockets to the CBE DS300 distribution box, the old system had a 12v circuit.
many thanks
Allan
  • DS300-UK.pdf
Why bother,i would start from scratch using a new led fuse block ans sep wires to each unit,ie ,lights toilet ,tv,and any heaters etc.
use a up to date charger and a mains switch over in case you find a site with x wiring.
If solar is on roof then a mppt unit as in pics as this will also charge hab and starter batts.
More simple to fault find and replace one unit if it goes down rather than it all in one sys.
A11an
Thanks for the reply, he's already bought the kit and to be honest it is mostly just a swap over job, I'm just not 100% where to wire the 12v sockets.
Has he got the connector plugs to go into the connectors on the unit? I have not used the CBE300 but it seems to be fairly self-explanatory where the circuits come out looking at the documentation.
My personal way Allan would be to run the 12v power supply off the 20 amp AUX power supply. Phil
A11an
Thanks Phil, that was my first thought but in the end as he only has 1 light circuit I used the the B light group as he wanted everything of when the control panel is off. Allan
Yes it's much of a muchness light cct is using a 20amp fuse so would be fine for a 12v socket cct 👍.Phil
