Carver cascade 2 water heater wiring
T X
Has anyone got an example of there Carver cascade 2 water heater installed?
Be really helpful if you can post a picture of how you've done it.
Thanks,
Mark.
T X
The plumbing side, does it have a built in water pump or do I need to get one to put the cold water in?
no,you'll need a pump
cold water into the lower pipe,hot from the top. the cold inlet has a small pipe and tap for draining in winter,freezing will kill the heater !
T X
When the hot water is ready would there need to be another pump to go to the shower or should the pump pushing the cold water do it?
mikejay
One pump as it pushes cold in the hot comes out. You can have a system were the pump pressurises the system up then as you open the tap or shower it kicks in or a switch or micro switched taps that turn the pump on as you open a tap.
Mike
