		On my return from a weekend camping trip last week and after 3280 miles on the continent last month I  clocked up exactly 60.000 miles on the van from new, and on braking the "Check brake pads" warning showed up on the dash several times and so made a mental note to have a look during the week.
The last time I changed the front and rear pads was exactly on 30.000 miles, the fronts at that time were close to metal and the backs were about half worn but I decided to fit new to both front and rear.
On inspecting the fronts they again were almost down to the metal infact the sensors had actually worn away, so I'll have to remember that when the check brake pads warning comes up again it means it as there is obviously very little leeway given. The back pads were still in good shape so I left them be.
The moral of this post is if you have a Sevel van then if your close to 30.000 or 60.000 or any multiple of 30.000 then best check your pads, admittedly my van weighes in at 3606kg so maybe a bit heavier than most but still it does seem that the front pads on these vans are needed to be changed at 30.000 mile intervals. Phil
