listerdiesel
Been fairly busy with bits and pieces, the Bullfinch external LPG point came this morning, and I've been chopping up a sizeable chunk of nylon to make the adaptor for the extraction fan in the bathroom.
Industry being what is is, there's little standardisation between parts that have the same function, so the 12V extraction fan has 88mm or 98mm over its body, the mushroom vent takes 85mm pipe. You couldn't make it up!
There is enough roof void space to use a sleeve that can be double-diameter so it fits both articles.
So I started with a 175mm long chunk of cast nylon, 110mm diameter. I put it on the Rapidor hacksaw to cut it down, but it was a right so and so to cut, I had to keep feeding lubricant to it or it would overheat and melt.
Peter
Peter
