Superseal connectors
Chris Evans001
God, what a bloody misery wiring superseal connectors! Seems a real knack to them... Glad a bought spares.
Although weatherproof and seem popular, I had to give up trying to make them in the van. Just too fiddly so brought it all inside and sat at a bench to do them. šŸ„µ
Yes you need to ruin a few before you get the knack.
ps. Give the terminals a good pull to make sure they are crimped properly.
I didn't know they went by the name of "superseal" connectors! I've got a load of those :). They can be fiddly for sure and one limiting factor I find is the cable gauge they support (pretty limiting). Using thin-wall cable also makes it a little easier.
FWIW, I usually use needle-point pliers rather then crimpers (the connector is so small it is hard to see what you are going with big crimpers I find) and solder the wire as well.
