Possibly a stupid question but....
I want to remove both of the leisure batteries, however they are wired directly to the solar panel, is it OK to simply disconnect the connection without covering the solar panel over?
you should either cover the panel (or cover enough to 'kill it') or remove either the +ve or -ve PV connectiom into the controller (I would do this rather than cover the panel).
also, maybe your controller can be turned off? (for example, with the Victrons, you can go into the settings and simply turn them off)
Yes just pull the fuse or remove pos wire into control unit from solar panel,mine are fussed both sides ,into control regulator and out of to batterys with a fuse box.
