Changing toilet
paul h
http
://www.jabscoshop.com/files/MAN%20TWIST%20N%20LOCK%20toilets%20doc632.pdf
has anybody used one of these in there build seen one or used one in the flesh so to speak im thinking of fitting one and a holding tank
outtolunch
http://www.jabscoshop.com/files/MAN TWIST N LOCK toilets doc632.pdf
If you have somewhere you can empty a holding tank you can have a greater waste capacity but if planning to be away for long trips finding a place to empty the tank is not as easy as with a hand portable waste tank.
ps. have used them but that was on a canal boat and it developed a list to port as it filled and the pump out station was several pub stops away.
vwalan
is it really worth the bother?
i prefer a simple old style portapotty over a cassette type nice and simple nothing to go wrong .
Deleted member 951
They're known as Sea Toilets, and are a barsteward to fix when they block!
