Working weather coming for outside house conversation.
Spent some time in van over the last few months, found some items that need change now. 1
the snug seat 100cm so a bit short behind drivers seat is only good for eating = table . But as we only spend 1 hour in that position, we need improvement as the lounge time reading drinking and looking out of side door its not good. Or comfortable.
The Right angles has to go and need foot rest as the seat base is 70cm from floor including pad. 50cm without. So thinking of a unit that sits between the two front seats for lounging but not fitted or not fixedi in place, That converts to make a oversized single bed in walkway.
So new design is the red lines in photos.
Black drawings is how now.
2
kitchen unit as 4th photo in need of a worktoo but curian is not as good for frying pans hot bottoms. But its lights.! Is there any other work top metials, I should think about ? builders , for thin worktop.2500cm x 60cm x 10mm
3
bedroom wall coverings. Just broke a 2 and 3 seater and found cardboard inside making the curved shapes ! That somethime I never thought of.
So the door frames on the rear compartment barn doors needs insulation and shapein ! Will the cardboard absorbe mostister and deforom once coverd from frames ?.
This is the cloth we got at£10 per meter 19.5 m over 3 colours
Red is swade for headboard plus body cushions
And silver and bronze is wash a ble non absorbent = wipe clean for walls and ceiling. It is warm to to the touch. Pic 5 and 6
Question is all 3 comes with a backing metial ! Should I remve backing stuff for better glueing ?. To cardboard. ?
TIA
Any help / advice is always good. To get van finest.
Just been to foam shop in Taunton took van got 19 m of 6mm for walls 1sheet of 4 inch blue and 4m of wadding .plus the block to do the bench seat 60x60x60 = £441. Ouch ! Were up to 9 degrees
A Most expensive 20 mins.
So that sidedoor window was meant to start today
Its freezing in april
