Water fittings
coolasluck
Does anyone know where i can get hold of inline dump valves so as i can empty my system if needed?
Alf
Dump valve
Just use a standard tee joint to feed an in line tap fit as near the pump as you can and a discharge pipe through the floAlf
Smaug
as long as you don't leave water in the pump to freeze, cos that'll cost you a new pump.
schubert
Try here ,they do allsorts of water fittings .
CAK Tanks LTD Unit10 Princes Drive Kenilworth Warwicks.
Schubert
