This is possibly only relevant for those who use the Victron VRM system to look at their setup, but others may be interested?
The VRM has lots of performance data & information available on the various devices that are connected to the system.
This includes for solar the following:
PV Yield as denoted by the "System" (the "System" is the Victron GX Device that gathers the info, be it a CCGX, Venus GX, Cerbo GX, Raspberry Pi, etc.)
It also has PV Yield info for the Controller ...
Now what is the difference? Well, I have never quite known TBH when you have one controller and when I have compared them in the past the numbers have been nearly identical, so I thought it might have been a timing thing to poll/accumulate the data.
One thing I was sure of was that the "System" PV Yield would have been the total PV Yield for all Solar Controllers, as that would make sense to get the overall picture?
And as I do have two PV Controllers now, it would be useful
(when I actually have a panel on the 2nd one!)
I noticed a fairly large discrepancy here though ....
System Yield is 269W (which is pretty good from a 270W Array), but the Controller Yield is only 255W? where did either the extra 14W come from? or the missing 14W go? (depending which way round you look).
Well, the answer is as follows and was revealed with a negative Harvest!
I am getting a -14W Yield from the Solar Array? how is that possible? People talk about the battery backfeeding into the panels at night, or fitting bypass diodes to avoid a shading panel taking power, etc etc. But no, none of that nonsense, it is just a quirk of the way the data is collated and presented - but it is important to know if you are analysing solar performance over time as the Devices PV Yield is misrepresented IMO.
The full picture can be seen when you look at the Controllers Load Output chart as well
I am drawing around 1A from the load (e.g. around 14W).
If I look at the Controller using VE Direct, that tells me what the Load output is as well at the time
I have a pretty constant overhead of c 14W give or take a Watt or two connected to the Controllers Load Terminal (I have all the original Habitation electrics going through the Solar Controllers Load).
So to summerise ...
The Controller PV Yield is a net value of power from Controller to Battery (what Victron refer to as "Battery Watts") - so the Solar Array Harvesting is a contribution, and the Controller Load is a debit and the difference added together is the "Yield"
However the System PV Yield is the Solar Array Harvesting without any deduction for any Load connected to the Load Output.
It may be important to you to know the difference, but from the Titles, they would appear to mean the same
So to summerise ...
