Can someone explain what amps would be delivered on each output on maximum output, is it 20amps divided by number of outputs connected or 20amp on each connected output?
Victron Blue Smart IP22 Battery Charger 12V - 20A 3 Output.
For that specific charger (which actually happens to be one I possess), you will have a maximum of 20A, shared as required between the 3 outputs.
So if 1 battery connected, that will get all the charge upto 20A; if you had say two outputs, one on a leisure battery that needs a good charge and the other on the starter battery that needs a lesser charge, most of the charge will be directed to the leisure battery.
