Bigchaser
Hi Guys,
I totally confused, the more I read the worse it gets…… I want to wire in a very simple split charge system to power a Waeco CF 50 fridge in my Land Rover Camper, to allow the fridge to run all weekend while I’m away hill walking and not drain the starter battery.
I have been told the simplest is a voltage sensing relay, just 3 wires to connect. What size cables should I use to connect the two batteries? Does it have to be big cable like the cable from the battery to starter motor, or can it be smaller?
I need your advice guys???
