coolasluck
Ok you self builders.
I currently have 6 x 100 watt panels with a max imp of 33 amps going to a bus bar and then direct to a 45 amp morningstar charger.
This is fine but i also have a 120 watt panel that is fitted to the rear that is as yet unconnected.
I was thinking on running the cables also to the busbar and using the same regulator,this would add another 7.5 amps imp.
making the max imp power to 40.5 amps imp.The regulator is 45 amps and i am wondering what people think is the best way forward?
Also over 5 weeks i have managed to get a 150 amp charge from the 6 panels with only my compresser fridge running to use the power i am wondering what charge people are getting from their panels??
