Jake Drummond
Just a thought......how many hours of engine running at tickover would if take to offset the cost of fitting a solar panel for charging while off grid camping?
Can you enlighten me on your quick charge system please,i am very disappointed with my lb charging as my van has Euro 5 engine with smart alternator. bazzI don't have solar but have only ever once needed to run the engine to top up the battery, and that was because the battery needed replacing. With a quick charge system fitted it should only be necessary to run for half an hour or so to top up. I find that my 115ah battery lasts an easy three days in the depth of winter, even leaving the heating on full time.
Generators are never silent or anything near it, and I find them much more intrusive than a running engine.
Solar is only needed if staying in one place for a long time, or if inefficient lighting or heating is fitted. It may be useful to those with high consumption gadgets or who cannot connect to mains when stored.
A lot of course depends on each individuals type of use, personally moving regularly eliminates the need for solar or running the engine to charge.
WARNING THIS POST CONTAINS ESTIMATIONS AND ASSUMPTIONSJust a thought......how many hours of engine running at tickover would if take to offset the cost of fitting a solar panel for charging while off grid camping?
Park up next to me and idle your engine for three hours and you would definitely get flat tyres
No contest in my opinion,solar power is much cleaner and environmentally friendly than running the engine for long periods.Also you can go out somewhere and leave the van whilst the panel is constantly charging quietly in the background.
As has been said in winter you may need some back up,a generator(used responsibly)or CL/CS for a night with hook up would be my solution.
