Sliding door leak.
karlpe
I have a leak in my sliding door at the top. I have adjusted it best I can but no joy.
Any one any tips to deflect water over gap. I was thinking of some kind of little shelf type thing to deflect.
Any ideas be a great help.
molly 2
A common fault on sliding doors 1. Check rollers, can be worn or broken or missing ,adjust rollers to tighten gap at top of the door to seal , not as easy to do as it sounds as it can affect closing of the door , 2 check door seal for weare and damage a new seal can tighten the fit of the door 3 trap a thin card between door frame and seal should grip card when door is closed ,this may find a gap, 3 check for stones and debris in all channels .4 if all fails take cash and van to local body shop they can make some brutal adjustments to door's and frames .
