Grimola
Hi Everyone
I am completely new to the motorhome world so you may see me on here a lot over the next few months while I try a self build project! (I have very basic DIY skills)
I pick up my Peugeot Boxer minibus this weekend and want to start converting ASAP and work from the top down so will be doing skylights and Solar Panels as 1st jobs? I am unsure if there is any point installing roof lights as the bus has 2 huge opening windows in the rear
I want to reduce condensation as much as possible with out having to spend a fortune so my questions are:
1) Will roof lights make much difference to the amount of condensation in winter and coolness in summer? or will opening the windows be enough.
2) Are heki midi the best to go for- if so which variant, with electric fan, quad, standard ?
3) Will 1 roof light be ok or will I need 2?
4) Can anyone recommend fitters (or DIY'ers) in the Bristol are (10-15 MILE RADIUS) that can do this for a reasonable fee if I supply the parts? I have been quoted £350 for 1 sky light - so that's about £250 in labour which is a bit of a rip off!
5) Also need someone to do electrics - but may buy a pre made hook up/split charge harness so may DIY?
I hope to use fiends to help with the rest!
Thank you
Thank you
