Sikaflex
hotrats
Allo peeps,how long does sikaflex take to go off when used for mounting a soler panel,or when would it be safe to drive off?
Ta mucho for any advice givin.
saxonborg
If you use activator it would be quicker, downside is it is quite expensive.
shaunr68
I think I read somewhere it has a cure rate of 24 hours per 2mm thickness. I left it 24 hours before moving the van a very short distance and another 24 hours for good measure.
Admin1
When I fit panels I recommend 24 hours before moving the van. I now use Sikaflex 512 with activator.
Wooie1958
I`ve only ever used Sikaflex 512 and try to leave it a good 48 hours before moving, ideally fit friday and don`t move until monday at the earliest :hammer:
I also loosely cover overnight especially if a heavy dew is forecast for the first couple of days :scared:
harrow
I would make up a separate test sample that you can handle to see if it has cured,
I have been doing that with car fillers, araldite and other glues for years.
