Roof vent?
Deleted member 951
There are also several solar powered ones which will operate when you are not in the van helping to prevent mildew.
Deleted member 951
Thanks - any experience with them? Easy to fit? Let in water?
I've only a small van with future plans for a solar panel on the roof - that might take up a bit too much room ;)
I've used the solar panel driven ones on boats, obviously you will need to cut a hole, but the rest is a doddle. (use a good sealant like Sikaflex).
