		Something that I have wondered about is how much power the fan I have uses.
I've noticed in the recent weather that my power consumption has increased noticeably. It might be thought this is mainly due to the fridge having to work harder, but actually the fridge has not had to do much extra at all (surprising but true) and because I log the power consumption on a literal minute-by-minute basis, I can see the pattern is not fridge-related.
The other obvious 'culprit' is the fan, being put into use more with the hotter temperatures of course.
I have a MaxxAir 7000 Deluxe Fan (the 7500 is the exact same model but with a Smoked cover instead of the White cover - I mention this due to a typo in the graph later in the post) and that has an AUTO mode that changes the fan speed automatically depending on delta between Ambient vs Target temp, and also turns itself on and off. Becuase of this automatic mode, you can't tell for sure how the fan is running when away from the vehicle and so what power is being used.
So me being me, I decided to log it specifically
NOTE: The specific data is for the MaxxAir Fan I have installed. Other Fans will have different characteristics, but another Fan with the same CFM value is likely to draw the same power.
Test Environment:
Power taken from Leisure Battery reduced to minimum - So VSR disabled; both Inverters OFF )but there is a tiny residual draw as both can be turn on and off remotely); 3 x USB Dual Sockets powered up (nothing plugged in); Raspberry Pi powered up via a USB 3A PSU; Fridge Fan Temp Controller on (fan off); Water Pump on (not being used).
All the above results in a constant 3W draw on the battery - so that is our baseline without the Fan in use.
I then turned the fan on using manual mode only, setting it to the lowest setting - 10%. Approximately every 15 minutes I used the remote control to step up the speed to the next setting (so 20%, 30%, 40% etc. up to 100%). Finally hit the stop button and the fan turned off and the motorised cover closed.
The following graph shows the difference in power drawn for each speed, the value adjusted to remove the baseline power draw.
Maxxair Power Consumption by David, on Flickr
It is interesting that the first few steps are not that different from each other (and in use, the audible difference between 10% and 20% for example is very hard to hear) but as you get faster, the power differences widens.
I had previously noted that my fridge draws an average of about 1.2A/hour in use inc the Inverter O/H - If you compare that to the fan use, it is around the same as the fan running at 60% - this might surprise some folk?
The fan is great and I would recommend the MaxxAir 7000/7500 100% and without hesitation, but it is a powerful beast at the higher speeds and you would need a decent battery capacity or Solar charging if running the whole day.
PLUS - if using on AUTO mode, the fan may kick into higher speeds when the temp goes up and if the target temp set is not achievable, then you may be away from your van for the day, with the fan consuming 37Wh/Hr - which would be well over half the typical (100Ah) Leisure Batteries usable power (600W) used up in under half a day.
Test Environment:
Maxxair Power Consumption by David, on FlickrIt is interesting that the first few steps are not that different from each other (and in use, the audible difference between 10% and 20% for example is very hard to hear) but as you get faster, the power differences widens.
