boik
Hi guys. Just found this site which looks perfect for us.
We have a Toyota Previa T3 which we want to use for camping, but need to be able to use as a full 7-seater as well. Seats are quick and easy to remove/replace (and floor is completely flat) and I am well able to build a removable kitchen unit and bed/storage using the existing seat mounting for quick attach/release. I just have a quick question re the electrics. The car has a 7S socket so my initial idea was to put the electrics (leisure battery, fusebox, Waeco fridge, water pump and lighting) into the kitchen unit and have a lead with a plug that just plugs into the 7S pins 2 and 3 to charge the battery, and then connect everything else straight to the battery (via suitable fuses). Would this be acceptable for short breaks, or would everyone advise using a habitation relay and wire the fridge to pins 6 and 7?
Any thoughts/suggestions gratefully received.
