Propex exhaust?
daisymini
Do i need to put something in the hole in the bottom of my van for the exhaust? The van floor is ply as well as metal and i wondered about the heat from the exhaust affecting the ply..!
outtolunch
there should always be a gap between a gas flue and any combustible material I see the installation instructions state a 32 mm hole for a 25 mm flue and remove any carpet in the area, but if I remember rightly gas regulation state 25 mm away from any combustible surface so I would play safe and cut away the timber floor to give a 25 mm gap. This gap can be filled with any fireproof material if required to reduce draughts etc.
daisymini
Thanks for the info..very helpful..:)
hextal
my instructions say 40mm, but I note that the previous ones were 32mm.
Half tempted to go with 32mm as I have a step-drill that is just the right size
as I said to daisy,i cut an oval hole with a jigsaw that took both pipes with plenty of gap,and masticced the heater to the floor
