Kev
Hi.
Hopefully someone has some experience with one of these heaters and can help me with the benefit of their knowledge :bow:
I've just got hold of a Propex Compact 1600 (the discontinued orange one but not the older X1) and as I'm only partway into my build I have the option of several places to put it. However an important factor will be the temperature that the actual case itself reaches....
It could go either in the base of one of the kitchen cupboards (not ideal), in the bed locker (as a last resort as I need the storage space) or ideally in the space under where the fridge will be (obviously dependent upon the heat emanating from it). The fridge will be over the wheelarch and will give more than the recommended 1" clearance for the heater but would the heat from the casing interfere with the efficiency of the fridge, even with any attempts at insulating the space...
I've seen several of the newer Heatsource models installed under fridges but as these are more efficient than the older models there may not be as much heat lost through the case if you know what I mean.
So, can anyone give me an idea of how hot the case gets please :help:
