shinobidef
Hi all,
I've spent quite a while reading books and articles on electrics but I just can't seem to get my head around it - either the books go into more depth than I need, or are more to do with electronics components, or they describe someone else's set up which means I can't really adapt as I don't know or understand the knowledge behind their choices!
I've attached a rough schematic I've done and whilst I understand a bit more about the fuse boxes and fuses, can anyone help with the following:
I have 6 12V downlights and I'd like these in 3 x pairs (1 x pair on each of 3 walls) and I'd like each pair to be controlled by a switch.
I've been referring to wiring gauges using a table but (and this is quite a basic question!) it says to use the "roundtrip" length when working out the sizes. Suppose the lights are 2 metres away, does that mean I need 4 metres of positive cable and 4 metres of negative, or 2 metres of positive and 2 metres of negative? Do the +ve and -ve go all the way to the appliance AND all the way back?
I'm also having problems understanding which wire to use for the solar panels and if I should be wiring in series or parallel. I have 2, each at 315W and a Vmpp each of 30.4, which I think makes them just over 10 amps each. The lmpp current is 7.58 per panel. However, nearly all the guides I read say your solar panels will be 6V, 12V or 24V - where is that figure coming from? My electric system is 12V so are they referring to the output once it's gone through the MPPT controller?
Thanks in advance!
- Do I run one cable from the fusebox and split it into 3 separate circuits (so 1 x 1A fuse at the fuse box as the lights are 2W each)? If so, what do I need to use to split it? I'm confused with the difference between connector blocks, bussbars, etc. so I'm not sure what I should be looking for! Also, if I were to use a large cable and split it, would I be splitting into separate purchased smaller gauge wires for each pair of lights, or can the large one be split into 3 different circuits?
- Or do I run each pair of lights direct to their own place in the fusebox?
Thanks in advance!
