I have done a little bit of research and I am coming to the conclusion that if the battery charge parameters in technical details are pretty similar than mixing battery types should not be too much of an issue. I understand that best practice would be to have an array of the same battery types but I am pretty sure I can chuck the AGM I have, this one:
www.alpha-batteries.co.uk/leoch-160ah-agm-leisure-battery/
into a circuit with THREE of these
www.alpha-batteries.co.uk/12v-90ah-bosch-powerframe-leisure-battery-l5013-lfd90/
without causing terrible damage to any batteries.
Now I understand that with the AGM the charge cycles are greater at 600 vs 200 for the Wet Cell, so potentially the Bosch batteries could wear out faster than the Leoch AGM but my feeling is that I can "get away with" pretty much mixing the 4 Batteries to give me MAX 520AH which I think should be sufficient for up to a week off grid using diesel heater, LED lighting and some tech.
Thoughts, anyone ? TIA
