Soxandjeff
I am in the process of furnishing my van.
For those who have fitted microwaves in their vans .. how did you fix them down please?
Thank you. I`m a little nervous of putting crews into it when I don`t know what`s on the inside.We do have one fitted that has only been used twice but I dont know how it is held down, I think it has a plate at the back holding it but not sure. I am not back in the van for a few days but will see if I can find out over the weekend and post again if I can
I don`t think the microwave will be a permanent feature and will change to a small gas cooker in the future.If you open the outer shell look where screws can go without contacting anything, use l brackets to hold down, dont just let it sit as flying objects can kill.
Where are you going to get power for that,gas hob/oven better.
No problem Neil and thank you for your time.Sorry John I have looked at this a few times now and cannot see how it has been fixed, I can see a piece of alli angle if I look down the side (not easy to spot unless you are looking for it) but I can’t se anything going through the shelf, I removed the cover piece above the fridge so I could see.
It must have been built on to the shelf as it was assembled and I don’t want to dismantle the unit. That is probably the best way if you can design with a removable shelf. You could glue bracket (angle) to shelf and screw to back of microwave then slide shelf in and retain.
