Little jems when shopping
When out van shopping. Got foam from foam shop tauton . i orderd in march and he gave me 3 tins of spray glue . Then pulled into scrap yard and got some 20 20 ! 2 slot and 4 slot so kitchens a gooden and 2 lovly 100x50x2000 bed supports . im loving it
. 40 kg = £60.
Question
Best way of cutting aluminum 20 20 for kitchen cabinet unit and over head unit ?
I have angle grinder , I have hacksaw got miter or should i buy chop saw and blade. As I've saved already. !
Rage chop saw every time....
It'll cut all sorts with one blade and depending on the model all sorts of fancy angles....
Not sure I could do without mine now.
jp11
2020's perfectly adequate, but a bit limited in the size of bracket fixings. I'd like to know where to get it second hand though! I even used it for the toilet compartment. Cladded it with IKEA wardrobe doors.
Longest bits ive found are 1200mm . Would love 1800 as that the lenght of the kitchen work top and floor to ceiling.
But the beds made from paito frames at 1770 acrosss takes longer to fabricate, but so much stronger than 4x2 as wont bend as the 4x2 has done..
