forager
Due to change in circumstances (house sale fallen through), considering building a stealth camper for say, 50/50 split of wild camping and campsite. (May also tow a caravan at times and live in that during the winter)
Has to be fairly simple with regard to washing and cooking etc. Van probably won’t be big enough for a shower and that’s probably beyond me. Fixed bed, under bed storage, WC, fold up sink and single hob. 2 x water containers under sink for fresh and waste water?
Is it realistic to go all electric and no gas? Keep it simple, no gas, no flues, and generator similar size as 2 x gas bottles?
Yes a generator can be noisy and annoying but if wild camping and no one nearby, a well silenced generator should not be a problem.
When on campsite, use hook-up.
2000 watt suitcase silent generator, built in to further sound-proofed box. Box completely sealed to internals of van. Box externally ventilated, air inlet to engine, exhaust pipe to external. Could be used in transit? Would need to be a generator with its own forced air cooling fan and preferably electric start, is there such a model?
5 litre, 1500 watt, insulated catering urn (next to sink) for hot water/quick wash and drinks (£85)
(Unused hot water poured in to flask and used for drinks) Just need cold water tap to sink?
12 and 240 volt fridge (how many amps at 12 volts?)
1500 watt single hob for cooking by pressure cooker
3000 watt single hob (when using suitable electric hook-up)
2 x 110 A/H leisure battery, 12 volt lighting, 12 volt fridge, 300 watt pure sine wave inverter for electronics (charged from van or generator)
Not bothered about a TV, laptop goes 10 hours on a charge.
Not really interested in solar panels for this particular application where there is ample power from a 2Kw generator.
(Additional work, high cost, low output, selective weather required, wind noise and drag)
Thinking about a diesel heater, believe fairly simple to fit, interested in best type?
May be able to fit the generator, petrol can and diesel heater all in the same sealed box to keep the smells out of the van?
I wild camp at present with just a petrol stove so this lot will be luxury.
Constructive ideas welcomed, thanks
