Inverter cutting out
xsilvergs
What is the significance of this to the poster issue? If it is a battery issue (which I think is likely), it will be the BMS and not a cell design type that is probably the problem.
Can a battery using Pouch Cells deliver a high current? Here is a single 100Ah Battery fitted with Pouch Cells providing over 90A to help run a Microwave. That is 1168W (With Inverter losses).
Sorry I'll keep my mouth shut in future.
Many inverters can at best only deliver 2/3 of the so called rated power, I have a smart soft start nikkaI 600w constant, well in fact it will not run my 500w plug in wall heater, so I had to go down to 400w unit which now stays on without cutting out.
Do you not have gas to heat things, much better by far.
