Gas box project complete...
AuldTam
I've just completed a gas box in my self build...I've been looking for a metal box to fit over a 7kg gas bottle for ages then when I was in the shed the other day I remembered I had some metal shelves from an old stationery cupboard...measured them up against the gas bottle then set to work...I nipped out this morning and bought a metal blade for the jigsaw and some pop rivets...I took the ply door off the existing gas box and made a metal box to fit inside and a metal liner on the back of the ply door, job done....I'm well chuffed with myself :king:
ellisboy
Nice one ! Any pictures Chap ? :banana:
ellisboy
#5
Nice one :banana: Have you put a drop out hole in ?
AuldTam
#6
No not yet...I'm giving it some thought as I would like a plastic sleeve with mesh inside to keep insects out.
Any idea's?
ellisboy
#7
Yes! I've used pipe inserts,they are used in push fit plumbing,they come in different sizes.where ever I've drilled a hole in the floor ( gas drop out, waste pipes etc) then I've used an insert.For the gas drop out you could use soffit vents.Both of these items can be bought from Toolstation.if you spent £10 then it's free delivery.They sell lots of usefull things for selfbuilders.
:cheers: Stephen.
AuldTam
#8
:cheers: Stephen.
Thanks...I'll have a look
