daisymini
View attachment 11865View attachment 11866View attachment 11867
The problem i have is where i want the flue to go on my ambulance conversion there is a structural piece of aluminium which i do not want to cut through for stability reasons.
In pic1 the aluminium is just below the flue and its about 50mm in depth, so i cant go below it as the angle for the flue is wrong.
As seen in pic 2 the height from where ive put the flue to the exhaust has a gap of about 100mm,
So my question is can i lengthen the tube on the exhaust t joint (pic3) to reach the flue, this shouldnt have any bearing on the operation of the exhaust system should it???
There advantage of buying an old ambulance to convert is that it is already insulated and lined...the disadvantage is not knowing where the structural supports are when you want to do anything...!!!!!
