Doog
Hi all
have a question which may well have been covered before. Have been searching the web for a while to look this up but couldn't find anything specific. Found lots of similar stuff but it all seemed a bit more complex than for what I want to do. I'm not much use with electronics but what I want to do seems simple so thought it worth an ask here.
I've bought one of those double cigarette light devices. Its quite clear how its meant to work, one end goes into the cigarette socket and the other has the option to plug in two more devices with cigarette lighter attachments or up to 2 USB devices. The USB ports are labelled 1A and 2.1A respectively.
What I want to know is, could remove the male attachment for plugging into a cigarette socket in the vehicle and wire it up, via my aux fuse box (currently housing blade fuses for water pump and lights) to my leisure battery and use it to power USB devices. Digital camera, iphone, ipod and ipad are all that I would want to charge. Basically I want the option to charge these devices when parked up for longer periods of time. I have a solar panel to trickle charge the leisure battery and will be using this setup in Spain and Portugal this summer. There are times when i envisage being stationary for a week or more.
Someone I spoke to said this sort of thing would just drain the leisure battery but I wanted a second opinion.
Also I don't really want to get involved with inverters if possible but that might be dictated by the types of devices I want to charge. I was under the impression that the ipod and iphone would be fine on a 12v system and the device is 5v 1A option for one USB port. In the same way the ipad needs 5V, 2.1A from the device to work on a 12v system. By the look of things on my device that should be fine?
Picture of device
Link to website
Any advice appreciated.
Thanks!
Picture of device
Link to website
Thanks!
