shinobidef
I have a 640w solar array (2 x 320W panels in series) - each panel has a VoC of 40.9, so that's a total VoC of 82 and a amperage of about 53A. Looking at the solar panels, they are 4mm with MC4s.
The solar panels need to be fed into a 50A MPPT controller which says in the instructions that a minimum of 10mm cabling should be used (but to be honest, it doesn't even look like the terminals would take anything larger). My battery bank has a voltage of 12 (2 x 6V).
Anyway, I've run my data into a few solar calculators to work out the cable I need and all of them are coming out with 4-25mm for a 3 metre distance between solar panel and MPPT with 3% voltage drop.
E.G. wire-sizing-calculator (distance doubled as per instructions - so 6 metres) - 15mm
Wire sizing calculator for Solar Panel Arrays - 4mm
http://www.solar-wind.co.uk/cable-sizing-DC-cables.html - 25mm
The confusion has arisen because:
1) A solar company has advised me to use the same cable as is currently on the panels (4mm) - quite a difference between what the calculators are coming out with - however, 4mm has only a 36A rating whereas my output into the MPPT will be 53A at most.
2) If I use anything larger than 4mm (as per the calculators), I won't be able to connect the cable to the male/female MC4 connectors currently on the panels, nor will I be able to fit anything larger than 10mm into the MPPT
3) I'm getting different outputs from the calculators which makes me wonder if I'm using them properly!
Can anyone help? I'm utterly bewildered!
