Was going to post this in one of my other threads but think it its own thread. Winter is getting closer so time to sort what I am going to do with mains charging. My generator is a Hyundai 1Kw rated at 900W continuous. While a bigger genny would give me more options I can handle this one and would struggle with a 2 or 2.2kw unit so I need to get the best I can to suit this. My battery bank is 2x100ah Lifepo4 battery’s plus I want to trickle charge to my starter battery
Charlie has a Ring 50a smart charger and that doesn’t run on the 1Kw genny, it needs more power. So far the best I can see in a single unit is the Votronic Pb 1250 Smt automatic charger at 840W.
The biggest single unit Victron is 30a, I would either need to get two smaller chargers or go to a MultiPlus I ‘think’ to use Victron.
I liked the second hand Votronic VAC 1230 30 Duo chargers but seller is still away and they are a little over my 900W limit. Not sure if I can adjust these to deliver 25a per outlet, does anyone know, that would bring it in on the 900W limit?
if I am only going to accept 30a then I will probably go with the Victron 30a 3 output charger but it isn’t really what I want.
Links to all three chargers below this, anyone got any other possible contenders or recommendations bearing in mind limitations in first paragraph?
Victron Blue Smart IP22 Bluetooth Battery Charger - 12V 30A, 3 outputs
Victron Blue Smart IP22 6-stage battery charger 12V 30A (3 output). Multi-stage, Bluetooth-enabled charger for boats, caravans, motorhomes, campervans.
www.12voltplanet.co.uk
