Zilcho
Hey all I was wondering if someone might be able to help me out. I'm currently planning out the wiring for my camper conversion but I've run into a problem, when running on batteries with the inverter switched on a loop would be made as the charger is coming off the consumer unit which would charge the batteries which would feed the inverter which would then feed the consumer unit.
I only need the charger on when hooked up to mains and the inverter on when not so any ideas on a best solution? I was thinking a separate RCBO for the charger straight off the mains instead of through the consumer unit maybe.
Here's a quick simple pic to show the problem. View attachment 22334
Thanks a lot,
Mark
Thanks a lot,
Mark
