Cassette loo stopped flushing.
karlpe
Hi, my cassette loo has stopped flushing when I press the flush pad. By flush I mean water shoots out and around the pan btw. Does any one have any idea,s and if it,s the switch can it be changed in situ.
Thanks.
wineciccio
is it electric operated flush?? if so check the fuse which in most of them can be clearly seen when you open the toilette/cassette door:cool1:
karlpe
Thanks, but fixed now. I found a vid on utube which said try the pump. which I just took out and tested and is kaput. New pump will go in tomorrow so happy days.
Tallyman
Hi,the pumps often seize up when not in use or left dry , the impeller sticks to the housing . Its sometimes possible to get it going again by just adding fresh water or lightly tapping the pump while pressing the switch a few times
karlpe
Thanks but it was just dead as a dodo.in 30 years of caravaning never had a loo problem so cant really complain.Sh1t happens .
