Cable for solar panel.
Stitch
I'm moving the sola pannel (100w)to the back of the van. So I can fit a skylight.. that's a job for another day. Any offers of help greatly received ?
So yesterday I went looking to buy some new cable. Impossible in Norwich. So can anyone recommend a supplier.?
Many thanksView attachment 47085
Deleted member 951
Mind rob red to red ,black to black ,and blew it to f- - -?
I don't bother with all of that colour coding malarkey Gordon.
If I can find a terminal and the connector fits, that's where it's going.
Deleted member 2572
Makes sense ?
Cannot wait to see how your gas and water systems operate ?
Byronic
For one X 100W panel I wouldn't be bothered with all that 6mm sq. solar cable malarkey either. 2.5mm sq. flat twin 25A should be fine.
Deleted member 951
I would go bigger if moving the panel further back.
Deleted member 951
Having consulted the table though, 2.5 should be ok!
I'm using 4mm on mine though as it certainly won't hurt and moneywise it's nothing.
Worthwhile getting UV-Safe cable. As mentioned, you can get this for around £10 for 2 lengths of 5M 2.5mm cable with MC4 connectors and that (IMO) would be spot on.
Byronic
What I've found is that the larger spec. cabling can in some circumstances be difficult to install ie less flexible and some terminals at the panels can be a tight fit, make that bloody awkward. Also twin flat 2.5mm auto cable is made within a protective sleeve, the larger sizes are supplied as single cables at least as far as I can ascertain.
Haaamster
Just bought 2 lengths of 6mm x 8 metre solar cable with connectors for £15 from Amazon :dance:
Stitch
Thank you everyone. I don't know why I didn't look to eBay straight away... now purchased two five meter lengths.. ?????
